INDUSTRIAL FLEXIBLE SHAFT #8
The "Ferrari" of the Flexible Shaft. These shafts are crafted to exacting standards by a team of engineers. Turn your bench grinder into a high powered rotary tool. These industrial strength flexible shafts will perform the toughest of jobs. The #5 model is designed to fit our 3/4HP Buffing Machine. The #8 model is recommended for heavy duty buffing machines. Both shafts attach to the counter-clockwise turning end of the motor. Please allow 1-2 weeks for these shafts to be manufactured. IMPORTANT: If ordering these shafts for any other motor than our 3/4HP Buffing Machine, including our Baldor motors, please contact us after placing your order to ensure the shaft fits your motor.
