Quick view Raytech sku: AV75 VIBRATORY TUMBLER - ADJUSTA-VIBE 75 MSRP: Now: $1,567.50 Add to Cart Compare Quick view Raytech sku: TV10 VIBRATORY TUMBLER - TUMBLE VIBE 10 MSRP: Now: $262.90 Add to Cart Compare Quick view Formax sku: WCB WHEEL CLEANING BAR MSRP: Now: $23.09 Add to Cart Compare Quick view Caswell sku: WR995 Wheel Rake (Complete Unit - Handle & Teeth) MSRP: Now: $24.19 Add to Cart Compare Quick view Caswell sku: WRAKE WHEEL RAKE TEETH MSRP: Now: $12.09 Add to Cart Compare Quick view Caswell sku: WBC7 WHITE BUFFING COMPOUND JUMBO MSRP: Now: $16.49 Add to Cart Compare Quick view Caswell sku: WBC5 WHITE BUFFING COMPOUND LARGE MSRP: Now: $10.99 Add to Cart Compare Quick view Formax sku: F515-6113 WHITE LIGHTNING STAINLESS ROUGE MSRP: Now: $18.69 Add to Cart Compare Quick view Caswell sku: WLR12 WHITE LIQUID ROUGE MSRP: Now: $15.94 Add to Cart Compare Quick view VIBRATORY TUMBLER - ADJUSTA-VIBE 75 Heavy duty & adjustable amplitude The AV-75 is a .75 cubic foot (5.6 Gallon) capacity machine that offers increased productivity over other models. The machine is equipped with a heavy duty drive system that includes amplitude adjustment and the same ... MSRP: Now: $1,567.50 Add to Cart Compare Quick view VIBRATORY TUMBLER - TUMBLE VIBE 10 Heavy duty finishing & rinsing The industrial model TV-10 has heavy duty drive and suspension combined with a tough, cross-linked polyethylene 10 inch bowl. Bowl capacity is .10 cubic feet (35 to 40 rings), has a noise reducing lid and a liquid drain... MSRP: Now: $262.90 Add to Cart Compare Quick view WHEEL CLEANING BAR Restores clogged, loaded and glazed abrasive belts and buffing wheels, by removing embedded grinding debris lodged and packed between the abrasive grit particles. Works like a giant eraser. Simply hold and press the cleaning bar firmly against the... MSRP: Now: $23.09 Add to Cart Compare Quick view Wheel Rake (Complete Unit - Handle & Teeth) Our wheel rakes make cleaning your buffing wheels easy. Offer the jagged blade to the edge of the spinning wheel, and work it across the face until the wheel looks bright and fluffy once more. This action, done periodically, will remove entrapped metal... MSRP: Now: $24.19 Add to Cart Compare Quick view WHEEL RAKE TEETH Our wheel rakes make cleaning your buffing wheels easy. Offer the jagged blade to the edge of the spinning wheel, and work it across the face until the wheel looks bright and fluffy once more. This action, done periodically, will remove entrapped metal... MSRP: Now: $12.09 Add to Cart Compare Quick view WHITE BUFFING COMPOUND JUMBO Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $16.49 Add to Cart Compare Quick view WHITE BUFFING COMPOUND LARGE Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The... MSRP: Now: $10.99 Add to Cart Compare Quick view WHITE LIGHTNING STAINLESS ROUGE STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and good coloring properties are also a favorite for buffing... MSRP: Now: $18.69 Add to Cart Compare Quick view WHITE LIQUID ROUGE White Liquid Rouge Metal Polish Whte Liquid Rouge is formulated for use on all aluminum to "cut down" and "color" in one operation. Brings up a high luster, leaving the surface clean and free of excess grease and dirt, while removing mild oxidation,... MSRP: Now: $15.94 Add to Cart Compare Previous 20 21 22 23 24 25 Previous 20 21 22 23 24 25 Compare Selected × OK
