WHITE LIQUID ROUGE
White Liquid Rouge Metal Polish
Whte Liquid Rouge is formulated for use on all aluminum to "cut down" and "color" in one operation. Brings up a high luster, leaving the surface clean and free of excess grease and dirt, while removing mild oxidation, water spots and grime.
- Shine & Polish Aluminum To A Mirror Finish
- Fast & Easy
- Removes Oxidation
- Restores A Bright, Shiny Luster
- Contains No Petroleum Distillates, Non-Toxic & Bio Degradable
SDS
3 Reviews Hide Reviews Show Reviews
Great product!
Liquid Rouge - Liquid Awesome
And excellent product. I used it to polish aluminum with a random orbital polisher and the result left me more than pleased. For the price you cant go wrong!
Loved it
I loved the thickness of rogue. Made applying very easy. Will be buying more of this.
