Use as a pre-plate to allow nickel or electroless nickel plating onto Stainless Steel.
Mix with 1.5 Gallons of distilled water and electroplate with a nickel anode at .07 amps per square inch for approx 20 mins.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
GHS Info
SDS
