Regular Nickel Crystals w/Brightener 1.5 Gal
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
works great
the best nickel plate solution on the market, worth every penny and did a wonderful job, bright any shinny with out buffing
Worked great, Thank You
very nice plating crystals. smooth and bright.
Good stuff
Had not fired up my Nickel kit in two years. Called customer service added a little brightener and topped off water.
