Zinc Nickel Plating Kit - 1.5 Gal
Introducing Zinc Nickel Plating
Plates A Highly Corrosion Resistant Zinc Nickel Alloy Plating
- Ideal For Highly Corrosive Environments - Five Times As Corrosion Resistant As Zinc Alone
- Plates A Bright Silver Corrosion Resistant Coating. Highly electrically conductive.
- Ideal For Fasteners, Calipers, Engine Components etc that are exposed to the elements
- A great, environmentally safe alternative to cadmium where color is not important (if you're trying to duplicate the look of Cadmium use our Copy Cad Kit)
- Plates Directly Over Steel, Iron, Zinc, Pot Metal, Copper, Brass
Kits Include:
- Two Plating Tanks And Lids
- Zinc Nickel Plating Chemicals (Add Distilled Water)
- Degreaser
- Zinc Anode
- Nickel Anode
- Copper Anode Connecting Wire
- Brightener
- Instructions
The Zinc Nickel System plates at 6V DC for approx 20 mins. Longer plating times will result in a thicker, more corrosion resistant layer.
Our unique chemistry and twin anode design allows the zinc nickel alloy to plate evenly and with consistent results. The kit includes four predrilled anodes (two zinc, two nickel) and copper wire to connect the two. Simply connect the anode pairs together and connect to your power supply's positive terminal.
GHS Info
SDS
