Restore dull, oxidized metal to a brilliant, mirror-like shine with White Diamond Metal Polish. This premium concentrated formula cleans, polishes, and protects in one easy step, removing oxidation, tarnish, discoloration, and stubborn road grime from a wide variety of metal surfaces.
White Diamond Metal Polish is formulated for use by hand or with a polishing machine. As it restores the surface, it leaves behind a protective sealant that helps preserve the shine and guard against future oxidation and environmental exposure.
One Polish. Countless Uses.
Bring back the shine on virtually any metal surface with White Diamond Metal Polish.
? Aluminum – semi-truck tanks, wheels, trailers, pontoons, motorcycles, exhaust pipes, bumpers, and trim
? Brass – instruments, fixtures, and hardware
?️ Stainless Steel – appliances, exhaust systems, and marine hardware
? Copper – fittings, decorative metal, and accents
? Silver & Gold – jewelry and specialty metal surfaces
Perfect For
Cars • Trucks • Motorcycles • Boats • RVs • Trailers • Wheels • Tanks • Instruments • Household Metal
? Also works great on discolored headlights to help restore clarity and improve their appearance.
From the garage to the road, White Diamond helps clean, polish, and protect the surfaces you want to stand out.
Additional Product Features
- Non-greasy wax finish helps protect and preserve the brilliant shine
- Removes minor blue and yellow discoloration from exhaust pipes
- Removes stubborn water scum lines from boats and marine surfaces
- Cleans, polishes, and protects in one easy application
- Leaves metal looking clean, bright, and professionally polished
Directions for Use
- Shake very well until the product is completely blended.
- Apply a small amount of product to a soft cloth.
- Rub vigorously onto the surface, following the grain of the metal.
- Allow the product to sit for approximately one minute.
- Using a separate clean cloth, wipe away the residue and buff the surface to a brilliant shine.
Note: The cloth will pick up black residue as oxidation and contaminants are removed. This is normal and shows that the product is working.
Videos Hide Videos Show Videos
