Small Plastic Polishing Kit
Kit contains:
- 1 x 6" string buff
- 1 x PLASTIC-GLO (Ultra Fine, dry grade)
Thousands of thin cotton string strands will buff all types of plastics, including bacolite, to a shiny surface. The buff is specially designed to keep the plastic cool.
Bring side markers, turn signals, tail light lenses to shiny, like-new condition. Thousands of 1-3/4" long cotton strands reach deep into details to gently polish and shine without overheating and melting plastic. Use in conjunction with our Plastic Glo Compound.
P-22 Plastic-Glo is an ultra-fine cutting and high coloring compound for bringing out a smooth, brilliant finish on practically every type of plastic. No. P-22 is a pure white compound on the very dry side. Will not glaze on the buff or load up compound into crevices or recesses of the work. Being exceptionally fine, it will not scratch the softest plastic. Nothing better for producing the very finest finishes on transparent plastics.
Great
leaves a nice clean polished surface on clear auto lenses.
