SALE Quick view Caswell sku: CWAL Casweld™ AL Aluminum Brazing Rod Kit MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Caswell sku: CWFX1 Casweld™ PM Flux - 2 fl oz MSRP: Now: $18.98 Add to Cart Compare SALE Quick view Caswell sku: CWPM Casweld™ PM Soldering Rod Kit MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Caswell sku: CWFX2 Casweld™ AL Flux - 2 ounces MSRP: Now: $18.98 Add to Cart Compare Quick view Caswell sku: CWCI Casweld™ CI Cast Iron Welding Rod Kit MSRP: Now: $61.99 Choose Options Compare Quick view Caswell sku: CWCIS Casweld™ CIS Cast Iron To Steel Welding Rod Kit MSRP: Now: $61.99 Choose Options Compare Quick view Caswell sku: CWKK Casweld™ Keep Kool Putty - 2 lb Tub MSRP: Now: $67.85 Add to Cart Compare Quick view Caswell sku: CWS1 Casweld™ Silver Solder Rod - 3/64 x 1 Rod MSRP: Now: $44.28 Out of stock Compare Quick view Caswell sku: CWS2 Casweld™ Silver Solder Rods - 1/16 x 2 Rods MSRP: Now: $125.24 Add to Cart Compare Quick view Techno Weld sku: TECH6RK TECHNO-WELD 6 ROD KIT MSRP: Now: $27.82 Add to Cart Compare SALE Quick view Casweld™ AL Aluminum Brazing Rod Kit Casweld™ AL Aluminum Brazing Rod Designed for joining all brazable grades of aluminum sheet, plate, tubing and piping, extrusions, rod and wire 5 Rod Kit (1/8" x 18") & 2 oz Flux Download our Casweld™ Product Manual Perfect for: ... MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Casweld™ PM Flux - 2 fl oz 1 x 2 Fluid Ounce Bottle of Casweld™ PM Flux For Casweld™ PM Solder Rods MSRP: Now: $18.98 Add to Cart Compare SALE Quick view Casweld™ PM Soldering Rod Kit Casweld™ PM Soldering Rod 350°F Melting Rods For Pot Metal and Thin Aluminum 4 Rod Kit (1/8" x 18") & 2 oz Flux NOW REPAIR POT METAL PARTS BEFORE PLATING WITHOUT DRILLING OR PUTTIES Download our Casweld™ Product Manual Perfect for: ... MSRP: $56.93 Was: $56.93 Now: $44.00 Out of stock Compare Quick view Casweld™ AL Flux - 2 ounces 1 x 2 ounce bottle of Casweld™ AL Flux for use with Casweld™ AL Aluminum Brazing Rods MSRP: Now: $18.98 Add to Cart Compare Quick view Casweld™ CI Cast Iron Welding Rod Kit Casweld™ CI Welding Rod Kit For joining of all weldable cast iron grades to themselves or to low carbon steel alloys. Available In 1/2lb Kits Of: 3/32" Diameter - 14 Rod Kit1/8" Diameter - 7 Rod Kit5/32" Diameter - 4 Rod Kit Extra strong arc drive... MSRP: Now: $61.99 Choose Options Compare Quick view Casweld™ CIS Cast Iron To Steel Welding Rod Kit Casweld™ CIS Cast Iron To Steel Welding Rod Kit Universal electrode for joining a wide variety of ductile, nodular and malleable cast irons. Perfect For Joining Cast Iron To Steel Available In 1/2lb Kits Of: 3/32" Diameter - 11 Rod Kit1/8"... MSRP: Now: $61.99 Choose Options Compare Quick view Casweld™ Keep Kool Putty - 2 lb Tub Casweld™ Keep Kool Putty can be used as a heat sink to absorb heat and avoid surface discoloration on heat sensitive parts. It can be used as a heat dam to prevent heat from traveling to areas that can be damaged by heat, such as O-rings, packing... MSRP: Now: $67.85 Add to Cart Compare Quick view Casweld™ Silver Solder Rod - 3/64 x 1 Rod Casweld™ Silver Solder Rod Download our Casweld™ Product Manual For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries 1 Pre-Fluxed 3/64" x 18" Rod Features: ... MSRP: Now: $44.28 Out of stock Compare Quick view Casweld™ Silver Solder Rods - 1/16 x 2 Rods Casweld™ Silver Solder Rods Download our Casweld™ Product Manual For color matching stainless steel and for low temperature high strength joints in the food, medical and pharmaceutical industries 2 Pre-Fluxed 1/16" x 18" Rod Features: ... MSRP: Now: $125.24 Add to Cart Compare Quick view TECHNO-WELD 6 ROD KIT TECHNO-WELD is a revolutionary material in the field of Aluminum Joining, and overcomes some of the major problems associated with traditional methods. SIMPLE TO USE - Joining with TECHNO-WELD is a similar process to gas soldering/silver... MSRP: Now: $27.82 Add to Cart Compare Compare Selected × OK
