Casweld™ CIS Cast Iron To Steel Welding Rod Kit
Universal electrode for joining a wide variety of ductile, nodular and malleable cast irons. Perfect For Joining Cast Iron To Steel
Available In 1/2lb Kits Of:
3/32" Diameter - 11 Rod Kit
1/8" Diameter - 7 Rod Kit
5/32" Diameter - 5 Rod Kit
Non-overheating, hard driving, Ferro-Nickel electrode for penetrating dirty-rusty contaminated cast irons.
Microstructure: Consists of an iron-nickel austenite with finely distributed graphite. Flux Color: Black
Excellent for joining cast iron to steel.
Extremely strong arc drive penetrates surface contaminants.
Special slag composition can be welded over without creating porosity.
Extra nickel content insures crack resistant machinable welds.
Recommended Current: DC Reverse (+) or AC
Diameter | 3/32" | 1/8" | 5/32" |
Minimum Amperage | 50 | 70 | 100 |
Maximum Amperage | 80 | 110 | 140 |
Deposition Rates:
Diameter |
Length |
Weldmetal/ Electrode |
Arc Time of Deposition min/ lb |
Amperage Settings |
3/32" |
12" |
.44 oz |
45 |
70 |
1/8" |
14" |
.76 oz |
22 |
90 |
5/32" |
14" |
1.07 oz |
20 |
120 |
Tensile Strength: 74,000 psi (550 MPa)
Yield Strength: 54,000 psi (390 MPa)
Elongation: 22%
Hardness: Rockwell B 88-90, Brinell 180, Vickers 189
Welding Techniques: Adjust the welding machine to the lowest proper setting that yields good welding conditions.
Welding Positions: Flat, Vertical up, Horizontal, Overhead
MADE IN THE USA
GHS Info
SDS
