30 Amp Plater
This heavy duty unit will plate larger items. Will nickel & copper plate items up to 3 sq ft in area.
Not suitable for anodizing, due to it's lack of constant current mode.
- 0 - 20 Volts d.c.
- 0 - 30 Amps d.c.
- Continuously variable output control
- 5 way output terminals
- 23 lbs. 13"W x 8"H x 8.5"
Warranty Information
30 Day WarrantySafety Information
