120VDC 1 AMP RECTIFIER
For Titanium Anodizing. Provides a high voltage, low amperage DC current
Features
- SMD adhesive sheet element technology for internal pcb construction
- Attractive yellow large LCD display
- Built in cooling fan
- Multiloop high precision voltage regulation
- Progressive current regulation
- Dual terminal system. Safety test style or expandable screw terminals
- Overload protection circuit
- Low ripple voltage: <1mV P-P
- Output polarity: positive or negative
- Rugged reinforced metal frame construction
- Source effect: 5 x 10(-4) =2mV
- Load effect: 5 x 10(-4) =2mV
- Ripple coefficient: <250uV
- Stepped current: 30mA +/- 1mA
