RECTIFIER - 250 AMP
250 Amp Rectifier
- DC Output: 250 amperes 0-12 volts
- AC Input: 110 volt 1 phase 60 hz
- Cooling: air
- Control: manual powerstat
- Ripple: 5% or less at any setting
- Metering: analog dc ammeter and voltmeter
- Cabinet: plastic approx 16" high x 27" wide x 18" deep
- Amp Draw: 30 amperes maximum
