DIGITAL RECTIFIER - 3 AMP
Buy 3 Units, Get the 3rd Unit Half Price
3 Amp Constant Current Rectifier
Constant current/voltage power control
This new system has the latest technology for small plating and anodizing operations. The constant current control is particularly useful for anodizing using the Caswell LCD Anodizing system.
Several of our plating
systems use small amounts of current, and if plating
parts with only a few square inches, this can
sometimes be a real problem to obtain accurate
current outputs from larger machines.
The system will operate comfortably at 1/10 of
an amp.
To operate:
For constant amperage control:
- Adjust the voltage knob to the maximum clockwise position
- Switch the power ON
- Adjust the amps knob to the desired output voltage
- Connect the plating tank to the unit
For constant voltage control
- Adjust the amperage knob to the maximum clockwise position.
- Adjust the voltage knob to the minimum anti-clockwise position.
- Switch the power ON.
- Adjust the voltage knob to the desired amperage requirement
For restricted current protection:
- Adjust amperage knob to the maximum anti-clockwise position.
- Adjust voltage knob to the desired voltage position.
- Connect to the plating tank
- Adjust the amperage knob clockwise to set the output current at the desired level for restricted current protection.
In the event of a short circuit, at the output, the current will limit at the value set by the current controls, however the unit should be turned off and the short circuit removed before continuing use.
Specification:
- Input voltage: 110 ac 50/60Hz
- Line Regulation: CV < 0.01% +1mV
- Load Regulation: CV< 0.01%+3mV(<3A)
- Ripple & Noise: CV<0.5mVr.m.s (1<3a)
- Protection: constant current and short circuit protection
- Voltage Indication Accuracy: 1%+2 digits
- Current Indication Accuracy: 2%+ 2 digits
- Environment: 0-40 deg C
4 Reviews Hide Reviews Show Reviews
works great
I am very happy with mine and works great
awesome
This digital rectifier works really well for anodizing
Excellent rectifier for Hull Cells and small parts!
As our older small rectifiers turn into junk, we have been replacing them one by one with this 3 amp model. Not only are they inexpensive, they are always dependable and easy to use, too when we need to plate small parts or Hull Cell panels.
Good plating rectifier at a very good price.
We have purchased these digital rectifiers in the past and they have served us well in our lab. We did not have to think twice about ordering another one even though the others are still functioning well. We just needed another reliable replacement of an older analog model.
