null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • Flash Copper Plating Kit - 3 Gals Flash Copper Plating Kit - 3 Gals
    Flash Copper™ Plating Kit Improved Formula Provides Better Adhesion and Finer Plate Plates directly on steel, copper, brass, stainless steel, zincated aluminum, tin, nickel, electroless nickel and sulfamate nickel as well as die-cast zinc surfaces -...
    $265.09
    Add to Cart
  • Flash Copper Plating Kit - 4.5 Gals Flash Copper Plating Kit - 4.5 Gals
    $369.04
    Add to Cart
  • GP PLATE - 20" x 20" x 1/32"
    "General Purpose" plates. Ideal for larger anodizing systems (use as cathodes), or stripping tanks. Lead sheet is 1/32" thick. Can also be used as an anode when chrome plating.
    $59.39
    Add to Cart
  • Hard Chrome Plating Kit - 1 Gal
    Hard Chrome Plating Kit Chrome plating can be used for two purposes: Hard Chrome Plate Usually used to build up shafts or areas on steel that are subject to severe wear. The hard chrome plating process can take several hours to build up. The procedure...
    $180.39
    Add to Cart
  • LIQUID DEGREASER CONCENTRATE GAL
    The correct surface preparation prior to plating is of the utmost importance. Slight traces of grease or oil, even finger prints, can completely ruin a good plating job. Yet most commercial systems use harsh alkaline cleaner that are tough to handle and...
    $36.29
    Add to Cart
  • MASK IT MASKING LACQUER - 8OZ
    Caswell Mask It Masking Lacquer is an optically Blue Tinted acid resistant, peelable coating used where an acid resistant protective coating is required. Various applications include: protection of surfaces during fabrication and milling operations,...
    $12.09
    Add to Cart
  • Mist Control Balls - 2 sq ft
    Due to the high current usage during chrome plating, a mist of acid is produced from the tank. This can become a nuisance due to the corrosive nature of the product and its yellow stain. The Complete Plating Manual shows how to control...
    $44.54
    Add to Cart
  • NICKEL ACTIVATOR - 1 PINT
    Use to activate a nickel plated surface before gold, silver, nickel or copper plating. Simply swab the activator over the nickel, rinse, then plate. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA...
    $18.14
    Add to Cart
  • NICKEL ACTIVATOR - 1 QUART
    $30.24
    Add to Cart
  • Nickel Electroforming Kit - 1.5 Gal
    New Sulfamate Nickel Formula Electroforming is a process where electroplating is used to create entire parts out of a certain metal, using molds or dies. Electroforming can be achieved with our acid copper plating process, and now, with our new Nickel...
    $265.09
    Add to Cart
  • Nickel Electroplating Kit - 1.5 Gal Nickel Electroplating Kit - 1.5 Gal
    Improved More Complete Kit - New, Bigger Sizes Learn How To Nickel Plate Using This Kit With Our New E-Class - Now Available Enroll In Our E-Class For Free When You Purchase A Nickel Plating Kit* Read More About Our E-Class Here - $99.00 Accessory...
    $301.39
    Add to Cart
