Caswell Mask It Masking Lacquer is an optically Blue Tinted acid resistant, peelable coating used where an acid resistant protective coating is required.
Various applications include: protection of surfaces during fabrication and milling operations, plating process masking, anodizing process parts mask.
Mask It air-dries quickly, leaving a tough and flexible coating that is easily removed from a variety of surfaces.
Mask It is the ultimate in solvent-based removable coating technology.
Mask It easily peels off the surface when plating or anodizing is completed.
Hazardous Shipping Info
GHS Info
SDS
Great product
Fast shipping
