The correct surface preparation prior to plating is of the utmost importance. Slight traces of grease or oil, even finger prints, can completely ruin a good plating job. Yet most commercial systems use harsh alkaline cleaner that are tough to handle and extremely caustic, causing fumes and quickly burning skin etc. They can also cause catastrophic corrosion of aluminum when it is immersed for even a few seconds.
Our newest degreaser chemical comes ready to use and is completely safe for all metals, and the environment. Quickly penetrates grease, oil and dirt on contact. In just seconds you can wipe away even the toughest stains. Bio-degradable and phosphate free. Use it for plating, anodizing, powder coating, and all your automotive and household cleaning needs. Use at room temperature and at full strength.
GHS Info
SDS
Best stuff around
I use this exclusively for my anodizing because I don't like having to heat up the degreaser I use. This stuff doesn't need to be heated prior to use. Just brush off the part in the degreaser with a toothbrush and rinse and your good to go. I do not like that they call it concentrate as concentrate implies that it can be diluted and this can only be diluted by 15% and does evaporate like water so keep it covered when not in use. I plan on using this stuff in a sonic cleaner to make sure that the parts are totally clean without having to hand clean each one, but it really isn't necessary as this cleans parts incredibly fast.
