NICKEL ACTIVATOR - 1 PINT
Use to activate a nickel plated surface before gold, silver, nickel or copper plating.
Simply swab the activator over the nickel, rinse, then plate.
Hazardous Shipping Info
GHS Info
SDS
4 Reviews Hide Reviews Show Reviews
Great product
Easy to use
excellent product
much have product
works
I used this and it worked great
great stuff
Very happy with it, and plated very well after I used this
