GP PLATE - 20" x 20" x 1/32"
"General Purpose" plates. Ideal for larger anodizing systems (use as cathodes), or stripping tanks. Lead sheet is 1/32" thick. Can also be used as an anode when chrome plating.
awesome
Worked great!!
awesome kit
I don't do many reviews but I had to on this one works great you won't be dispointed
