null
Additional Items Required
Get Our Plating Manual
Plating Kits
  • 10.0 PH BUFFER SOLUTION
    DIGITAL PH TESTER FOR PLATING SOLUTIONS Accurately measures pH ranging from 0-14 pH. Pocket-sized, lightweight instrument will quickly test all your plating solutions, and even your swimming pool water. The unit is splash-proof, and has one point...
    $6.59
    Add to Cart
  • 120VDC 1 AMP RECTIFIER
    For Titanium Anodizing. Provides a high voltage, low amperage DC current Features SMD adhesive sheet element technology for internal pcb construction Attractive yellow large LCD display Built in cooling fan Multiloop high precision voltage regulation...
    $240.89
    Add to Cart
  • 24CT GOLD PLATING SOLUTION - 1 GAL
    Caswell 24ct Gold will plate directly onto tin, copper, brass, bronze, nickel, silver and most lead free solders. Some alloys must be copper or nickel plated first. Steel must be nickel plated first. Contains 2 pennyweights gold per US Gallon of solution.
    $794.19
    Add to Cart
  • 24CT GOLD PLATING SOLUTION - 1 PT
    $127.04
    Add to Cart
  • 24CT GOLD PLATING SOLUTION - 1 QT
    $228.79
    Add to Cart
  • 24CT GOLD PLATING SOLUTION - 2 GAL
    $1,361.24
    Add to Cart
  • 24K Gold Tank Plating Kit - 1 Gal
    24ct Gold Tank Plating Kits Work safely with cyanide free gold to plate jewelry, flatware, baby shoes, flowers, bathroom fittings and much more.  Caswell 24ct Gold is ideal for immersion plating of larger items. For brush plating...
    $845.89
    Add to Cart
  • 24K Gold Tank Plating Kit - 2 Gal
    $1,450.89
    Add to Cart
  • 3D Printed Parts Plating Kit 3D Printed Parts Plating Kit
    Plate 3D Printed Parts Easily Plates over PLA, ABS, PVA, Nylon and More Includes Highly Conductive Graphite Bearing Paint Easily Create Professional Looking Metallic Parts At Home Plates A Bright, Smooth Copper Plated Finish. Professional Grade Plating...
    $273.90
    Choose Options
  • 4.0 PH BUFFER SOLUTION
    $6.59
    Add to Cart
  • 5 AMP CC RECTIFIER
    5 Amp Constant Current Rectifier Ideal for small anodizing runs, small plating jobs. Will anodize parts up to 1 sq ft. Will nickel & copper plate parts up to 70 sq in.   Other options: Wamptek Dr Meter Hanmatek
    $213.40
    Add to Cart
