Caswell 24ct Gold will plate directly onto tin, copper, brass, bronze, nickel, silver and most lead free solders. Some alloys must be copper or nickel plated first. Steel must be nickel plated first.
Contains 2 pennyweights gold per US Gallon of solution.
GHS Info
SDS
