Caswell 24ct Gold will plate directly onto tin, copper, brass, bronze, nickel, silver and most lead free solders. Some alloys must be copper or nickel plated first. Steel must be nickel plated first.
Contains 2 pennyweights gold per US Gallon of solution.
GHS Info
SDS
Your Gold plate solution vs others
Truly terrible product. Using rectifier set to recommended voltage and amps on ultrasonic cleaned nickel plated items. The parts first came out looking patchy and reddish. I removed the plate, cleaned and re-plated in the I mmersion tank. The color still did not look at all like gold on all 6 parts plated. I then plated said parts with solutions from Beckerindustries and also a cyanide based solution from Cohler Enterprises. These parts came out perfectly with no issues whatsoever. I called Caswell for advice and was told they would email me to have me send photos and solve problem. A month later, no email, no response. I’ve been a buffing customer with Caswell for over 15 years. Disappointed to say the least!
