Quick view Caswell sku: CCFC1 Copy Chrome/Flash Copper Combo Kit - 1.5 Gal MSRP: Now: $311.18 Choose Options Compare Quick view Caswell sku: CCFC4 Copy Chrome/Flash Copper Combo Kit - 15 Gal MSRP: Now: $3,199.17 Add to Cart Compare Quick view Caswell sku: CCFC2 Copy Chrome/Flash Copper Combo Kit - 3 Gal MSRP: Now: $524.96 Choose Options Compare Quick view Caswell sku: CCFC3 Copy Chrome/Flash Copper Combo Kit - 4.5 Gal MSRP: Now: $698.27 Add to Cart Compare Quick view Caswell sku: CHRC10G DECORATIVE CHROME CRYSTALS - 10.5GALS MSRP: Now: $694.47 Add to Cart Compare Quick view Caswell sku: C15C Decorative Chrome Crystals and Catalyst 1.5 Gal MSRP: Now: $137.87 Add to Cart Compare Quick view Caswell sku: ALDEOX28 Deoxidizer/Desmut - 1 Quart MSRP: Now: $27.19 Add to Cart Compare Quick view Caswell sku: DCMPK Die Cast Model Plating Kit MSRP: Now: $113.84 Add to Cart Compare Quick view Caswell sku: EC2 Electrocleaning Kit - 3 Gal MSRP: Now: $113.85 Choose Options Compare Quick view Caswell sku: ELCUSENS Electroless Copper - Sensitizer - 1 Gal MSRP: Now: $227.70 Add to Cart Compare Quick view Caswell sku: ELCUSENS1Q Electroless Copper - Sensitizer - 1 Quart MSRP: Now: $67.85 Add to Cart Compare Quick view Caswell sku: ELCUACT Electroless Copper Activator - 1 Gal MSRP: Now: $379.50 Add to Cart Compare Quick view Caswell sku: ELCUACT1Q Electroless Copper Activator - 1 Quart MSRP: Now: $113.85 Add to Cart Compare Quick view Caswell sku: ELCU1 Electroless Copper Kit - 1 Pint MSRP: Now: $163.19 Choose Options Compare Quick view Caswell sku: ELCU2 Electroless Copper Kit - 1 Quart MSRP: Now: $314.99 Choose Options Compare Quick view Copy Chrome/Flash Copper Combo Kit - 1.5 Gal Includes a 1.5 Gal Copy Chrome Plating Kit and a 1.5 Gal Flash Copper Plating Kit. Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating. 1.5 Gallon Kit... MSRP: Now: $311.18 Choose Options Compare Quick view Copy Chrome/Flash Copper Combo Kit - 15 Gal Includes a 15 Gal Copy Chrome Plating Kit and a 15 Gal Flash Copper Plating Kit. Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating. 15 Gallon Kit: ... MSRP: Now: $3,199.17 Add to Cart Compare Quick view Copy Chrome/Flash Copper Combo Kit - 3 Gal Includes a 3 Gal Copy Chrome Plating Kit and a 3 Gal Flash Copper Plating Kit. Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating. 3 Gallon Kit: 3 x... MSRP: Now: $524.96 Choose Options Compare Quick view Copy Chrome/Flash Copper Combo Kit - 4.5 Gal Includes a 4.5 Gal Copy Chrome Plating Kit and a 4.5 Gal Flash Copper Plating Kit. Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating. 3 x 6 Gal... MSRP: Now: $698.27 Add to Cart Compare Quick view DECORATIVE CHROME CRYSTALS - 10.5GALS READ MSDS BEFORE OPENINGMix with 1.5 Gal distilled water and one 6 fl oz bottle of Chrome Plating Catalyst. MSRP: Now: $694.47 Add to Cart Compare Quick view Decorative Chrome Crystals and Catalyst 1.5 Gal Mix with 1.5 Gal distilled water and one 6 fl oz bottle of Chrome Plating Catalyst. Not available to residents of California unless an appropriate permit has been obtained. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to... MSRP: Now: $137.87 Add to Cart Compare Quick view Deoxidizer/Desmut - 1 Quart 1 Quart mixes with 2 gallons of water. Use to minimize smutting of aluminum parts before anodizing or plating. Use at 70-110 deg F, for 1-3 minutes. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA... MSRP: Now: $27.19 Add to Cart Compare Quick view Die Cast Model Plating Kit Zinc die-castings have, until now, been a difficult material to plate for the small operation. Die-casting manufacturers have used dangerous chemicals and cyanide copper... MSRP: Now: $113.84 Add to Cart Compare Quick view Electrocleaning Kit - 3 Gal Caswell Electrocleaning Kit Electrocleaning is a highly effective and fast way of cleaning parts prior to plating. It will remove oils, rust, grease and even paint. The part to be cleaned is hung into the cleaning solution and then connected to the... MSRP: Now: $113.85 Choose Options Compare Quick view Electroless Copper - Sensitizer - 1 Gal For use with our Electroless Copper Plating Kit. Sensitizer is the first step in the process. Used as is. MSRP: Now: $227.70 Add to Cart Compare Quick view Electroless Copper - Sensitizer - 1 Quart For use with our Electroless Copper Plating Kit. Sensitizer is the first step in the process. Used as is. MSRP: Now: $67.85 Add to Cart Compare Quick view Electroless Copper Activator - 1 Gal For use with our Electroless Copper Plating Kit. Activator is Step Two in the process. Used as is. MSRP: Now: $379.50 Add to Cart Compare Quick view Electroless Copper Activator - 1 Quart For use with our Electroless Copper Plating Kit. Activator is Step Two in the process. Used as is. MSRP: Now: $113.85 Add to Cart Compare Quick view Electroless Copper Kit - 1 Pint Electroless Copper Plating Kit Introducing a new, simple way to make non-metallic parts conductive. Easier to use than conductive paints. The Electroless Copper Plating Kit provides an even, consistent layer of copper, which can then be plated with Acid... MSRP: Now: $163.19 Choose Options Compare Quick view Electroless Copper Kit - 1 Quart Electroless Copper Plating Kit Introducing a new, simple way to make non-metallic parts conductive. Easier to use than conductive paints. The Electroless Copper Plating Kit provides an even, consistent layer of copper, which can then be plated with Acid... MSRP: Now: $314.99 Choose Options Compare Previous 5 6 7 8 9 10 11 12 13 14 15 Next Previous 5 6 7 8 9 10 11 12 13 14 15 Next Compare Selected × OK
