Copy Chrome/Flash Copper Combo Kit - 3 Gal
Includes a 3 Gal Copy Chrome Plating Kit and a 3 Gal Flash Copper Plating Kit.
Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating.
3 Gallon Kit:
- 3 x 3.5 Gal Plating Tanks & Lid
- 2 x 6" x 8" Copy Chrome Anodes and Bandages
- 2 Packs Copy Chrome Crystals with Brightener (Makes 3 Gals)
- 2 x Copper Anodes 4" x 8" and bandages
- Flash Copper™ Part A - 4 Quarts
- Flash Copper™ Part B - 1 Quart
- Flash Copper™ Part C - 1 Quart
- 1 Pack SP Degreaser (Makes 4 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Hazardous Shipping Info
GHS Info
SDS
