Includes a 15 Gal Copy Chrome Plating Kit and a 15 Gal Flash Copper Plating Kit.
Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating.
15 Gallon Kit:
- 3 x 20 Gal Plating Tanks & Lids (12W x 24L x 18H)
- 2 x 18" x 20" Copy Chrome Anodes and Bandages
- 10 Packs Copy Chrome Crystals with brighteners (Makes 15 Gals)
- 2 x Copper Anodes 18" x 20" and bandages
- Flash Copper™ Part A - 20 Quarts
- Flash Copper™ Part B - 5 Quarts
- Flash Copper™ Part C - 5 Quarts
- 8 Packs SP Degreaser (makes 16 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
