Includes a 1.5 Gal Copy Chrome Plating Kit and a 1.5 Gal Flash Copper Plating Kit.
Ideal for nickel plating ferrous metals like steel, iron & diecast/pot metal parts, where an alkaline copper strike is required before Copy Chrome plating.
1.5 Gallon Kit Contains:
- 3 x 2 Gal Plating Tanks & Lid
- 2 x 6" x 8" Copy Chrome Anodes and Bandages
- 1 Pack Copy Chrome Crystals with Brightener (Makes 1.5 Gals)
- 2 x Copper Anodes 4" x 8" and bandages
- Flash Copper™ Part A - 2 Quarts
- Flash Copper™ Part B - 1 Pint
- Flash Copper™ Part C - 1 Pint
- 1 Pack SP Degreaser (Makes 4 Gals)
- 2 x Pump Filter/Agitators
- The Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
Hazardous Shipping Info
GHS Info
SDS
