Built from Insulator Wax technology, this super slick Topper/Maintainer combines high gloss shine and durable hydrophobics in a fast and easy sprayable application.
Fast & easy to use, Insulator Speed Wax combines high gloss carnauba shine with Collinite’s legendary polymer durability. Creates a super slick, protective barrier that weather guards for months against contaminants. Can be used as both a gloss booster/protection topper after a Collinite wax coating (No. 845, No. 476s or No. 915), or as a stand-alone wax-sealant protectant. Safe on all exterior painted surfaces and trim. Not for use on rubber or glass.
Available in 16 fl oz
Average Spread/Coverage: 600-1,000 sq ft
TIP: Always test product first in a small, inconspicuous area to ensure desired result.
