Removes surface contaminants while leaving behind radiant shine and coating of rust-preventing protection
- Tough on rust and stains, yet easy to use
- Restores, shines and protects in one step
- For a variety of metal surfaces
Brings faded, tarnished and lightly rusted metal accessories and fittings back to life. This rejuvenating cleaner-wax saves both time and money by combining restorative and protective properties in one step. Safely removes stubborn discoloration, oxidation, and blemishes. Wipes off to reveal high luster shine and coating that guards against future rust, stains, and weathering. Contains no harsh alkali or acids. Handcrafted and poured in the USA.
1 Pint Bottle
