COLLINITE COLOR-UP PREWAX CLEANER
Removes film, mild oxidation/discoloration, brake dust, oil, grease, tar, bugs, stains and more from clear coat/single stage paint, painted/non-painted metal & fiberglass. Brightens surface clarity and deepens shine while preparing finish for follow up wax-improving bond, spread and protective durability. Clear coat safe. Not for glass, rubber or trim. Contains no waxes or silicones. For both hand & DA polisher use.
1 Pint Bottle
