COLLINITE ALL IN ONE One Step Polishing Wax
Renews neglected paint and provides a high gloss shine with lasting paint protection.
- REMOVAL OF MINOR PAINT DEFECTS
- FOR HAND & DA USE. BEST RESULTS FOUND BY DA.
- PROVIDES HIGH GLOSS SHINE
- 2-3 MONTHS OF PAINT PROTECTION
All in one cleaner-polish-protectant renews neglected paint and provides high gloss shine while protecting against future weathering. Micro abrasives gently restore clarity by removing brake dust, light water spots, minor swirls & other mild contaminants that washing will not eliminate from finish, while carnauba-polymer wax blend enhances gloss and brightens dulling surfaces-leaving behind a level of durable paint protection not commonly found in single step products.
- Available in 16 fl oz
- Average Spread/Coverage: 400-700 sq ft
- Optimal results found by machine
