COLLINITE LIQUID INSULATOR WAX
Unique combination of high gloss shine, ease-of-use and long-lasting weather defense
- #1 selling, “most talked about” Collinite product
- Easy on, easy off application
- Durable weather protection
A user-friendlier version of the No. 476s paste, No. 845 stands as Collinite’s most legendary product to date. Famous for its versatility, durability and DIY ease of use, “IW” is ideal for both small and large surface area jobs where lasting protection and timely job completion are desired, but hard buffing and frequent reapplication are not practical. Leaves behind carnauba shine and durable coating that preserves finish and shields against the elements; UV, rain, snow, salt, dust, dirt, grime, bugs, staining and more. Handcrafted and poured in the USA.
1 Pint Bottle
3 Reviews Hide Reviews Show Reviews
Extreme Durability & ease of application/removal
This...stuff...rocks. Hand's down, the most durable wax you're going to get your hands on. Period. I enjoy layering this over a high end sealant, and on especially pristine paint jobs on nice looking cars, I'll top it with a high end wax for the added depth and warmth. This stuff, 5 months after application, still beads water. Water spots simply wash off with a wash mitt, no clay, no cleansing required. Just simple maintenance washing is all you need. Highly recommend anybody that is prepping a vehicle/atv/anything that can be waxed for fall/winter/spring, this is your best bet. Layer over a sealant for the longest lasting effect, and always clean your paint before application for best results. Clay, paint correction, whatever that may be, the cleaner your paint is, the longer lasting the LSP will be. I give this a 6/10 in the shine department, and 10/10 for durability - simply because I would consider this more of a sealant, than a wax.
Nice wax.
Nice wax, potent and works well.
Nice wax.
