Featuring an SiO2+ graphene structure, this easy to use sealant provides ultra durable hydrophobics and a high gloss, super slick finish to variety of automotive exterior surfaces.
No.100 Beadcoat SiO2 + Graphene Spray Sealant quickly provides ultra-durable hydrophobics + a high gloss, super slick finish to a variety of automotive exterior surfaces. Featuring a functional ceramic-graphene resin structure, this easy-to-use formula provides 6+ months of stand-alone paint protection and UV/detergent-resistant shine. Beadcoat can also be used to enhance & preserve an existing ceramic or graphene coating. Safe for paint, glass, wheels & trim.
Available in 16 fl oz
Average Spread/Coverage: 600-1,000 sq ft
TIPS: Always test product first in a small, inconspicuous area to ensure desired result.
*For optimal bond/protection, ensure surface is free of above-surface contamination; this can be achieved with iron remover + clay process (towel or bar). Below-surface paint imperfections (swirls/ scratches/marring) should be removed by DA Polish
As a lubricating drying aid: Following a wash-while vehicle surface is still wet-apply 2 sprays of Beadcoat to one 3×3 ft panel at a time. Using a microfiber towel, wipe entirety of panel until dry. Flip towel as necessary, and change towels as they become saturated. Repeat process on all painted surfaces (and glass). *This process is only recommended if a previous base coat of Beadcoat has been applied.
