Cerakote Micro Slick Dry Film Coating
C-110 Micro Slick is a ceramic dry film coating used to reduce friction on a variety of internal firearm components, such as bolts and bolt carriers.
C-110 has a blue/grey appearance and is an air cured ceramic coating.
Application Guide
