Cerakote Piston Coat Ceramic Thermal Barrier
A dark brass/gold with a soft metallic finish.
Piston Coat is a thin film ceramic thermal barrier, designed to be applied on internal engine parts that require a thermal barrier.
Typical uses: piston tops, combustion chambers, valve tops, external turbo housings and exhaust components
