null
Rectifiers, Category Path: Plating Kits
  • 120VDC 1 AMP RECTIFIER
    For Titanium Anodizing. Provides a high voltage, low amperage DC current Features SMD adhesive sheet element technology for internal pcb construction Attractive yellow large LCD display Built in cooling fan Multiloop high precision voltage regulation...
    $318.57
    Add to Cart
  • DIGITAL RECTIFIER - 3 AMP
    Buy 3 Units, Get the 3rd Unit Half Price 3 Amp Constant Current Rectifier Constant current/voltage power control This new system has the latest technology for small plating and anodizing operations. The constant current control is...
    $187.67
    Add to Cart
  • RECTIFIER - 12V/500A - 220V 3 PHASE
    500 Amp Rectifier DC Output: 500 amperes 0-12 volts AC Input; 3 phase either 220 volt or 440 volt Cooling: air cooled Control: manual powerstat Metering: analog dc ammeter and voltmeter Ripple: 5% or less at any setting Cabinet: approx 31" high, 25"...
    $14,203.65
    Add to Cart
  • RECTIFIER - 250 AMP
    RECTIFIER - 250 AMP
    250 Amp Rectifier DC Output: 250 amperes 0-12 volts AC Input: 110 volt 1 phase 60 hz Cooling: air Control: manual powerstat Ripple: 5% or less at any setting Metering: analog dc ammeter and voltmeter Cabinet: plastic approx 16" high x 27" wide x 18"...
    $8,740.40
    Add to Cart
  • RECTIFIER - 30 AMP
    RECTIFIER - 30 AMP
    30 Amp Plater This heavy duty unit will plate larger items. Will nickel & copper plate items up to 3 sq ft in area.  Not suitable for anodizing, due to it's lack of constant current mode. 0 - 20 Volts d.c. 0 - 30 Amps d.c. Continuously variable...
    $461.55
    Add to Cart
  • RECTIFIER 0-30A, 0-32V
    30 Amp, 32V Constant Current Rectifier Best for anodizing. 32V allows for increased current densities and shorter anodize times Please note, during the current supply chain crisis, we may substitute this item for a similar item that WILL perform as well...
    $659.93
    Add to Cart
