Rectifier 100 Amp - 6 Volt DC.110 volt. 1 phase AC 100 Amp
Units are designed and manufactured to the highest quality standards and are guaranteed by the manufacturer against defects in material and workmanship for a period of one year from the date of purchase. This guarantee is limited to repair or replacement of defective parts that do not show evidence of damage by accident, abuse or unauthorized circuit modifications.
