RECTIFIER 0-30A, 0-32V
30 Amp, 32V Constant Current Rectifier
Best for anodizing. 32V allows for increased current densities and shorter anodize times
Features:
- Output Voltage: 1-32 VDC Adjustable
- Output Current: 1-30A
- Ripple And Noise: 5mV r.m.s.
- Line Regulation: 20mV (+/- 10% Variation)
- Load Regulation: 50mV (0-100% Load)
- Power Source: 120VAC/60Hz, 6.3 amps
- Meter: Digital LED (+/-1% +2counts)
- Dimensions: 7.9" x 3.5" x 10.8"
- Weight: 7 lb
- Contents: Power Supply, Power Cord, Users Manual (PDF - 781kb)
Please note, during the current supply chain crisis, we may substitute this item for a similar item that WILL perform as well as the item pictured.
Great Power Supply
This power supply is great, it is easy to operate and it has features that are not spoken about in the discription. When it is first turned on the unit automatically goes through a self test that checks the fan and other items as well.
