CERAMIC TRIANGLES 1/4 - COARSE
Ceramic Triangles 1/4"
Coarse aluminum oxide used wet
Aggressive heavy cut down removes heavy flash
Recommended for heavy cut-down & de-burring
Cycle Time: 3-5 hours
