- Gives A Shining Finish to Brass, Silver, Copper, Titanium, Stainless Steel Parts
- This tumbler can be operated with any dry media
- Designed to be used as a polishing tumbler to finish parts to a high luster
- Transparent polycarbonate lid
- Tight bowl/lid for dust free operation
- In-line power switch
- Heavy Duty, Thermally Protected Motor
- Quiet Running
- Wide, Stable Base with Protective Motor Shield
- Twice as fast as other tumblers
- Bowl capacity .11 cu ft = 0.822857 gallons
- Voltage and wattage, 115V
- Product size and weight: 10.5” x 10.5” x 10.5” 7lbs
- Recommended dry media and compounds: Dry Media only Nut or Corn Cob
