Aluminum Oxide 1 lb 120 Grit
For use with buffing wheel cement. Apply cement evenly onto a buffing wheel, then lightly roll the wheel in the Aluminum Oxide grit of choice. Leave the coated wheel to air dry for several hours prior to use. Subsequent applications will provide a longer lasting system. Gentle heat from an oven will speed up drying times considerably. As the oxide wears off, the wheel may be retreated numerous times.
SDS
Worked even better than I could have hoped.
Worked much faster than greaseless compounds. Glad I found this stuff!
