For use with buffing wheel cement. Apply cement evenly onto a buffing wheel, then lightly roll the wheel in the Aluminum Oxide grit of choice. Leave the coated wheel to air dry for several hours prior to use. Subsequent applications will provide a longer lasting system. Gentle heat from an oven will speed up drying times considerably. As the oxide wears off, the wheel may be retreated numerous times.![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
SDS
Kits may contain more SDS than listed here. Contact us for details
Worked even better than I could have hoped.
Worked much faster than greaseless compounds. Glad I found this stuff!
