Abrasive Wheel System
LOW COST FLEXIBLE GRINDING WHEEL
For use on your buffing machine!
Much more abrasive than the toughest greaseless compounds
Cuts through: PAINT, RUST, PLATING
Grinds away: SHARP EDGES, PITS, SCRATCHES, Parting Lines, Mold Marks, Tool & Die MARKS, STRETCHED METAL MARKS, BURRS ETC.
The Abrasive Wheel System comprises of a special adhesive, and a tough 80 grit aluminum oxide powder.
One the adhesive has hardened on the wheel of your choice, (usually a spiral sewn buffing wheel) the wheel is transformed into a tough, yet somewhat flexible grinding wheel, capable of grinding of plating, paint, rust, and smoothing out all metals.
The system is ideal for making felt bobs more abrasive.
Using a knife or spatula, the thixotropic adhesive is spread evenly around the face of your wheel.
Finally, roll the wheel into the abrasive using light pressure, ensuring a heavy pickup of the abrasive.
Leave the coated wheel to air dry for several hours prior to use. Subsequent applications will provide a longer lasting system. Gentle heat from an oven will speed up drying times considerably.
As the system wears off, the wheel may be retreated numerous times.
Abrasive Wheel Kit:
- 1 x 8oz Buffing Wheel Cement
- 1 x 1lb Aluminum Oxide 80 grit
SDS
Worked even better than I could have hoped.
Worked much faster than greaseless compounds. Glad I found this stuff!
