Glare Hurricane Pads (Set of 6)
The Hurricane Pads are made with the highest Reticulated German engineered foam and designed like no other pad.
Keeps the polish in front of the pad instead of seeping to the back, which keeps the polish from going onto the painted surface.
Longest lasting pad available anywhere in the World.
We guarantee these pads will wear better, and last way longer than any pad you have ever used! All pads are numbered to show you which pad goes with which product.
Buy the full set and save !
