Medium Cutting Pad
The Medium Cutting Pad for BuffPro® Model JF180 Axial Polisher, is an open cell polyester foam pad that works with your most aggressive compounds to provide unparalleled polishing power and accuracy. The wide bite and open cells mean that compound stays where the work is being done and that you take down rough spots quickly and uniformly.
We recommend the BuffPro® Medium Cutting Pad for use with medium compounds for light oxidation on gel coat, paint or 2000 grit wet sanding. The pad can also be used on stone, raw metal, epoxy fillers, pre-finishing prep work, fully-cured paint and polished concrete.
Designed for extended professional use, these pads easily wash out with soap and water and resist being saturated with compound.
