BuffPro® Pad | Heavy Cut Wool Pad
The Heavy Cutting Wool Pad for BuffPro® Model JF180 Axial Polisher, is a fine wool material over a foam pad that works with your most aggressive compounds to provide unparalleled cutting power. The compound stays where the work is being done and that you even out your roughest areas quickly and uniformly.
We recommend the BuffPro® Heavy Cut Wool Pad for use with your heaviest compound to remove swirl marks left by high speed buffers or orbital polishers, scratches, heavy oxidation, paint or 1500 grit wet sanding. Headlights can easily be restored using this pad and the BuffPro® Amber Medium Correction Compound. The pad can also be used on stone, raw metal, fiberglass, gel coat repairs, pre-finishing prep work and polished concrete.
Designed for extended professional use, these pads easily wash out with soap and water and resist being saturated with compound.
