BUFFPRO MODEL JF180 SWIRL-FREE POLISHER
BuffPro® Model JF180 Swirl-Free Polisher
110VAC - US Model
The BuffPro® Model JF180 Axial Polisher is a revolution in professional polishing offering a true swirl-free finish. Not only does the polisher not produce swirl marks, it can even remove swirls made by conventional rotary buffers. This is a tool that can buff and polish just about any surface in half the time of conventional rotating disk buffers. Our axial cylinder design means that compound stays under the buffing pad, while conventional buffers fling it off to other areas. The larger pad means that you can get better performance at much lower RPMs. We offer four high quality pads that work with the widest range of compounds to cut, polish, buff and finish to the highest shine possible.
BuffPro® Axial Polishers and Pads are designed for all-day use by professionals. Dual pistol grip handles, variable speed controls, a durable drive motor and a quick release pad spindle mean you can concentrate on your work not on your tools. And the low RPMs mean that its safe to use for the most novice detailer.
