Polishing Pad The Polishing Pad for BuffPro® Model JF180 Axial Polisher, is an open cell polyester foam pad that works with your milder finishing compounds to provide unparalleled polishing and finishing results. The wide bite and fine cells mean that compound stays where the work is being done and that you polish and finish all of your work quickly and uniformly. We recommend the BuffPro® Polishing Pad with polishing compounds for light scratches, haze, and minor imperfections in gel coat or paint. This pad can also be used on stone, fully-cured primed or painted metal, soft body compounds, and bringing raw metal to a high-gloss finish. Designed for extended professional use, these pads easily wash out with soap and water and resist being saturated with compound.
