BuffPro Finishing Pad
We recommend the BuffPro® Finishing Pad for final polishing, glazing or as a one-step wax cleaner. This pad can also be used on stone, fully-cured primed or painted metal, soft body compounds, maintenance on gel coat, finishing work and bringing raw metal to a high-gloss shine
. Designed for extended professional use, these pads easily wash out with soap and water and resist being saturated with compound.
