null
Get Our Booklet
Polishing
Download our FREE How To Buff & Polish Booklet and learn how to use these products.
  • FLAP WHEEL 60 GRIT 3 X 1
    These tightly packed and bonded sheets of resin bonded aluminum oxide are great for sanding, shaping and polishing all types of materials. Especially good for removing paint and rust. 1/4" shank works in any drill, drill press, flexible shaft, lather etc...
    $13.90
    Add to Cart
  • FLAP WHEEL 80 GRIT 1 X 1
    $7.58
    Add to Cart
  • FLAP WHEEL 80 GRIT 2 X 1
    $10.74
    Add to Cart
  • FLAP WHEEL 80 GRIT 3 X 1
    $13.90
    Add to Cart
  • FLAPPER ADAPTER - STANDARD - STAINLESS FLAPPER ADAPTER - STANDARD - STAINLESS
    The Flapper Adapter mounts onto any angle grinder with a 5/8 - 11 shaft (almost all grinders), and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs...
    $68.93
    Add to Cart
  • Flapper Adapter Metric M12 x 1.75 Flapper Adapter Metric M12 x 1.75
    The Flapper Adapter mounts onto any angle grinder with a metric M12 x 1.75 shaft, and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc. Made in...
    $68.93
    Add to Cart
  • Flapper Adapter Metric M14 x 2.0 Flapper Adapter Metric M14 x 2.0
    The Flapper Adapter mounts onto any angle grinder with a metric M14 x 2.0 shaft, and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc. Made in...
    $68.93
    Add to Cart
  • FLEX-A-GLU POLISHING WHEEL CEMENT 1 GAL
    A ready-to-use, water-soluble, synthetic adhesive for setting up polishing wheels and bobs made of cloth, canvas, felt, leather or wood. Apply by brushing on thin coats and rolling the wheel in a pan of loose abrasive grain. Multiple coats are...
    $46.16
    Add to Cart
  • Glare Aircraft Polish
    The Worlds Easiest to Apply and Take off Polish. No Powdering Up! AIR-GLARE® PROFESSIONAL AIRCRAFT POLISH is the most technologically advanced aircraft paint polish/sealant ever developed. This is the finest product for your airplane, jet, or...
    $55.65
    Add to Cart
  • GLARE BLAST QUICK N FAST
    GLARE BLAST is the most technologically advanced spray detailer polish ever developed! This is a true polish that blocks UV rays and protects paint against the environment. This is the only spray detailer polish with Camo-Adaptive Technology™ which...
    $48.69
    Add to Cart
  • Glare Car Detailing Gift Set
    Give the gift of clean car this Christmas. This kit has everything you need to clean your car's exterior. Give your car the best wash of it's life with the Glare Ultra Wash, and clean your rims with the Glare Turbo Action Wheel Cleaner.  Once it's clean,...
    $91.70
    Add to Cart
  • Glare Hurricane Pads (Set of 6)
    The Hurricane Pads are made with the highest Reticulated German engineered foam and designed like no other pad. Keeps the polish in front of the pad instead of seeping to the back, which keeps the polish from going onto the painted surface. Longest...
    $158.07
    Add to Cart
  • GLARE KNOCK OUT
    GLARE KNOCK OUT
    "Restores all paints, removes & reverses oxidation, and fills in scratches." Glassplexin actually fills in the surface scratches and reverses oxidation to bring the painted surfaces to a new level of beauty not available with any other compounds...
    $34.44
    Add to Cart
  • GLARE LIQUI-CLAY
    GLARE LIQUI-CLAY
    "The Clay Bar in a Bottle." Smoothes and removes stubborn blemishes before polishing! Won't rescratch your paint like a regular Clay Bar. Fast and very easy to use. The MOST advanced claying system for your vehicle's finish ever developed! Restores...
    $34.78
    Add to Cart
