These tightly packed and bonded sheets of resin bonded aluminum oxide are great for sanding, shaping and polishing all types of materials.
Especially good for removing paint and rust.
1/4" shank works in any drill, drill press, flexible shaft, lather etc.
![This product can ship air and worldwide This product can ship air and worldwide](/content/images/airok.png)
